Threads: 35
Thanks Received: 119 in 88 posts
Thanks Given: 3
4
20-06-2014, 04:41 PM
(This post was last modified: 20-06-2014, 04:41 PM by ntm1275.)
Has any one changed their diesel filter on their Mk3 1.6HDi?
I'm OK with the removal of the old one and fitting the new one, but I'm unsure about the bleeding
Any advice is much appreciated
Threads: 12
Thanks Given: 16
37
All you need to do is pump the bulb on top of the engine, keep going , sometimes it takes a couple of mins together the fuel up. You will know when you have got all the air out as you can feel the fuel inside the pump bulb. No bleed nipples to open, just keep pumping.
The following 1 user says Thank You to Lighty for this post:1 user says Thank You to Lighty for this post
• ron
Threads: 27
Thanks Given: 20
13
How often do owners in general change these, I know it's on the maintenance list but has anyone ever had one clog up?
Threads: 20
Thanks Given: 2,126
18
I change mine @ 25,000 instead of 36,000.That way it should never clog.They're not expensive so why not.Always use a good brand.
Strawberry flavoured windows
Threads: 12
Thanks Given: 16
37
They should be changed every second service . This coincides with the 25000 miles that Ron suggests, however, the newest van service intervals are 16000 miles, so that makes it every 32000.
Threads: 7
Thanks Received: 33 in 29 posts
Thanks Given: 5
08-01-2016, 09:37 PM
(This post was last modified: 08-01-2016, 09:40 PM by gazahull.)
quick tip.............fill new filter with half to three quarters full with clean diesel.........then do as above,.... pump bulb till hard to pump.........less air to bleed out......
The following 1 user says Thank You to gazahull for this post:1 user says Thank You to gazahull for this post
• ron
