  • 5 Vote(s) - 2.8 Average
[Engine] Flywheel locking hole 1.6 16V ???
How the hell to use it?? Do I have to remove the oilfilter? The exhaust manifold is very much in the way also...
Made a device like in the Haynesmanual, but...
Start by positioning the cam locking holes about 5degrees before they should lock with the pins, now I use long nose pliers to hold a right angle shaped piece of rod of the correct diameter in the hole applying pressure gently towards the flywheel, now get a partner to turn the engine slowly towards the cam locking position and you'll find the locking tool just drops in with a wiggle or two, no need to remove the oil filter tho Wink
[-] The following 1 user says Thank You to dumdum for this post:
  • addo
tensioner pulley
Last Post: RJBingham
Today 07:18 PM
» Replies: 19
Eberspacher or similar
Last Post: David Edwards
15-02-2019 01:10 PM
Overheat and antipollution?
Last Post: mikeB
15-02-2019 11:39 AM
» Replies: 26
Last Post: Grizz
14-02-2019 10:04 PM
» Replies: 651
clutch pedal
Last Post: gissa
14-02-2019 12:43 PM
Engine noise
Last Post: cancunia
13-02-2019 12:40 PM
» Replies: 16
Valves DW8
Last Post: Arbe
13-02-2019 11:11 AM
» Replies: 51
throttle cable - where to get a good one.
Last Post: Arbe
12-02-2019 05:35 PM
2003 2.0 HDI Poor fuel consumption
Last Post: ffrenchie
12-02-2019 04:23 PM
» Replies: 31
New Berlingo Anyone????
11-02-2019 11:13 AM
