  • 4 Vote(s) - 3 Average
1.6HDI Sarter Runs On
I have a just replaced by old 1.9d with a Mk2 1.6 HDI and when I start it the starter motor appears to run-on for a couple of seconds after the engine has fired and I release the key. Is this normal?
The starter is energised through the sw,therefore it will run until the sw is returned to ign/run.:thumbsup:Confusedalut: If it runs on appreciably the contacts in the starter solenoid may be trying to weld themselves together or return spring is broken.
Post your Ghetto Fabrication / Modifications "Ph...
Last Post: Kokain
Yesterday 12:26 PM
» Replies: 38
Horn not working
Yesterday 12:04 PM
Berlingo digital cluster speedometer upgrade
Last Post: kaktusas
15-12-2025 02:48 PM
Cruise control retrofit
14-12-2025 09:37 PM
14-12-2025 01:33 PM
14-12-2025 12:49 PM
14-12-2025 12:00 PM
Anti Pollution fault warning
14-12-2025 11:39 AM
An almost Hydrolock in a DV6B
Last Post: chrisl
14-12-2025 09:36 AM
Last Post: chrisl
14-12-2025 09:27 AM
