  • 15 Vote(s) - 3 Average
engine heater
engine heater this may be bilt in on berling sold in the north .norway .ussr i whood like one in my 2lt hdi i no you can get kenlowe ones but do thay make one that fits in the block to fit from new.
Try http://www.webasto.co.uk or http://www.eberspacher.com
They both make independant heaters which use a small burner to heat the engine coolant.
They can be used with a timer or remote control for pre-heating.
The other type,which is a small electric heating element that is fitted in place of one of the engine block core plugs,uses mains 220v.
A socket is fitted under the bonnet,or behind the grille,and a cable is then plugged in with the other end plugged into a mains outlet.
Not sure who makes this type,but try Bosch or Hella.
2010 XTR in black with bells and whistles
[Image: 5A50i.jpg]
Defa does electrical plug-in heaters, and I think they're also available in the UK.
Berlingo due in June.
Next gen Berlingo coming 2030
Last Post: shedpete
Today 08:36 AM
triangle light
14-06-2026 09:30 PM
13-06-2026 04:32 AM
Last Post: Jed Clampit
12-06-2026 10:44 PM
My Berlingo Multispaces
11-06-2026 05:21 PM
Last Post: ADarkDividedGem
10-06-2026 10:25 AM
08-06-2026 11:13 AM
Last Post: TGD
06-06-2026 09:50 PM
Last Post: CB-K9murph
05-06-2026 05:47 AM
03-06-2026 06:47 PM
