  • 2 Vote(s) - 4.5 Average
Fuel Tank - Baffled or Not?
I'm getting the distinct impression, there is minimal baffling in a Series 1 Berlingo tank.
Anyone cut a tank apart?
Thanks, Adam.
When my mk2 stops with a 3/4 full tank you can hear the fuel sloping around for quite a while so no baffling it my call.
[-] The following 1 user says Thank You to RolyG for this post:
  • addo
My v6 van used to die under hard cornering under 1/3 tank and I can confirm there is no baffles as far as my arm could reach Wink
[-] The following 1 user says Thank You to dumdum for this post:
  • addo
I actually noticed it handled quite a bit worse with a near full tank, due to that delayed slosh.
Baffling a tank could be fun! If one likes that sort of adventure.
  • RolyG
Today 06:32 AM
Clocks dropping out
Last Post: Micklew
Yesterday 09:29 PM
air con
Last Post: magoo1
Yesterday 04:56 PM
triangle light
Last Post: Buki
Yesterday 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
