  • 2 Vote(s) - 2.5 Average
Windscreen Pump
This is my first real post as I have managed to fix things from looking through previous threads.
My windscreen washer pump does not work, I removed it and tried power straight to the terminals with success. The pump works! Smile
This means there is a problem before the pump Sad and I have no idea where to start, can any point me in the right direction.
First place to look is in the handbook for the fuse that covers the washers. See if it covers anything else and if so is that working. That'll give you a guide. If fuse ok then trace wiring back to switch and check the switch itself.
Hth
Griff
Landmark
Ex 1.4 Berlingo Multispace
More than likely the stalk like landmark says
The wipers still work, is that still the stalk?
Yes it's still possible as there's different swithes for the different functions.
Are there 'just' a pump on the tank, or is there a second device there, too?
(An electrically operated valve, used to switch the output from the front to the rear)
No just the one pump, has the two wires coming in the top and one pipe coming out straight to the windscreen. There are no rear wipers.
I will look at the stalk tomorrow after work.
Cheers for the help Smile
hi cookie,,, more than likely its the relay switch,, its built in to the bsi unit and cant be removed from most mk1 models(hope i'm wrong). i had same problem.. i fixed it by putting in a seperate switch on the dash to work the pump,,, i'm 100% certain that in my case it was the relay,.. you should test the wires at the pump with a bulb if you havent a multimeter.
No luck so far so was thinking I might have to add a switch to operate the pump. Cheers for the help guys
I have the same problem, going to take it apart this afternoon.
Yesterday 04:12 PM
Yesterday 12:46 PM
Yesterday 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
