Threads: 21
Thanks Received: 32 in 21 posts
Thanks Given: 10
Looking for a 5 volt supply - anyone know of any circuit on the berlingo that I could tap into for this ?
Threads: 2
Most sensors have a 5 volt supply.
However it depends on the current your going to be drawing.
Threads: 16
Thanks Received: 31 in 22 posts
Thanks Given: 3
I think the output of the USB charger adaptors you can buy that plug into cig lighter are usually 5V 1 amp or 5V 2 amp if thats any help.
Threads: 21
Thanks Given: 10
Just giving this thread a wee bump just in case anyone may know of a 5 volt source within the berlingo? failing that I may have to use one of the other suggestions.
Threads: 2
Maf sensor would probably be easiest to take supply from due to its location however I am unsure if it would be affected in any way.
Good mpg by the way
Threads: 67
Thanks Given: 238
50
Out of interest what sort of sensor are you planning to run ? I'm being nosy to be honest and am curious as to what you are planning to do ......
For my own part I'd avoid sharing an existing sensor feed be it from a plug or the loom as every non original connection could possibly become a source of future troubles - water ingress, corrosion and high resistance. Perhaps there is a spare take off point you could utilise at source where the 12v is stepped down to 5 v this would require looking at the wiring diagram though.
Serieal Berlingo owner
