  • 8 Vote(s) - 2.75 Average
2.0 hdi air flow meter
ok so my new to me 04 2.0 hdi multispace has quite a list of problems mainly small im getting through them rightly,, lastest being it felt sluggish compared to my mk1 hdi this was confimed on driving another mk2 hdi same as my own far nippier of the mark .so first port of call was a full service no difference well small maybe then today i unplugged the air flow meter and bam different van to drive much more power so im asumming its kaput,, on ebay ive noticed they are only around 25 new? is there a genuine one bosch ect? what am i best buying?
If your looking for cheap have you thought about trying a scrappy?
The hdi engine is common to several cars/vans.
Be careful on ebay and make sure your buying from a uk seller (If you click on someones feedback score, it will tell you were they registered the account from) there are a lot of fakes on ebay.
Failing that ring around ecp/gsf/local motor factors to see which one is cheapest.
[-] The following 1 user says Thank You to homeruk for this post:
  • martybelfasthdi
Check the earth is ok to the airflow meter, they have a habit of dropping out which has the same effect, buying parts doesn't always prove cost effective Wink
[-] The following 1 user says Thank You to dumdum for this post:
  • martybelfasthdi
when i got my 02 berlingo 1.9d it was the same,30mph is all it was doing. I got a fault test done on it and it came back as air flow meter faulty on it, so my garage told me to clean it with electrical contact cleaner and leave to dry for half an hour before fitting it back,, i did what was told and the difference was massive, so i recommend you do the same, do not touch the sensors with your fingers as it will damage them, now my berlingo is doing about 46mpg. the sensor is responsable for sending back signals to the carb for increasing or decreasing the ratio of air to fuel mix,, make sure your air filter is clean or new
(09-07-2014, 04:53 AM)joemc20 Wrote:  the sensor is responsable for sending back signals to the carb for increasing or decreasing the ratio of air to fuel mix,, make sure your air filter is clean or new
Just trying to find the carb on my 2.0HDI....... Ideas anyone ???Confusedillyme:Confusedillyme:Confusedillyme:
well got a good used one of the bay genuine £25 and the van is much more responsive ect took a couple of days for the engine managment light to reset but it did good job!
(25-08-2014, 10:11 AM)martybelfasthdi Wrote:  well got a good used one of the bay genuine £25 and the van is much more responsive ect took a couple of days for the engine managment light to reset but it did good job!
Hope that fixes it for good!
Now back to hunting down the carb on my 1.6hdi......
[-] The following 2 users say Thank You to homeruk for this post:
  • andy-womble, martybelfasthdi
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
