  • 17 Vote(s) - 3.29 Average
buzzing noise out of speakers help me
I am getting a annoying buzzing noise out of the berlingo speakers when the ignition is on and stationary and also driving and the radio is off and when i turn radio on its still there and is this a warning noise or is the radio faulty?
the only light on the dash is the fog light it stays on all the time and rear fog light doesn't work its not the bulb
and I have put a new switch on the dash and wired it to the rear fog light to bypass this problem and it works fine now.
the buzzing is still there pls help
Hi Steve is it an original radio fitted also what model berlingo is it ? I would try pulling the plugs out of the rear of the radio and pushing them back in a few times ,did the noise just start or has it been there since you had it?
(10-07-2011, 11:33 AM)jimbo Wrote:  Hi Steve is it an original radio fitted also what model berlingo is it ? I would try pulling the plugs out of the rear of the radio and pushing them back in a few times ,did the noise just start or has it been there since you had it?
I bought it at auction 2 weeks ago its always been there and when i unplug the power to the radio it goes and comes back when I plug it back in
maybe I need a new radio
Your radio needs to be coded to your car/van...you will need someone with lexia 3 to code in your vin number which is used as the radio code into the radio ecu.
Here is a list of peugeot planet/lexia 3 owners who maybe willing to help out...:-)
http://www.peugeotforums.com/forums/main...-map-7734/
Ron.
(10-07-2011, 08:54 PM)Row Wrote:  Your radio needs to be coded to your car/van...you will need someone with lexia 3 to code in your vin number which is used as the radio code into the radio ecu.
Ron.
Thats not the problem I found a credit card size plastic with the code on and I used to and radio works but the buzzing is always there on or off
Ron.
Sorry mate....The newer peugeot/citroens use the vin number for the radio code.
What year is yours..?
Ron.
2002 and like I siad I found the code and it works
Last Post: BigVtwin996
Yesterday 08:25 PM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
