Coolant life
My '09 1.6Hdi 90 XTR is being serviced next week at 34000 miles by my ace Mobile Servicing bloke and I am confused as to whether I should have the coolant replaced or not. The service manual says just check it at each service, presumably only replacing it if it fails the check. I know the coolant can be checked for antifreeze efficiency but what about its corrosion inhibiting properties? I also have a 2008 campervan with the same engine, based on the Pug Partner and the manual for that says the coolant is there for the life of the vehicle. Are modern coolants really that clever now? If so I'll happily resist my old fashioned instincts to change it. My service engineer is also of the old school and a bit wary, though open to correction.
It's long life Just test it it just to make sure it's ok if it's green it last around 5 year's if pink/red the life is 10 year's :thumbsup:
[-] The following 2 users say Thank You to Jed Clampit for this post:
  • GJT, photoman06
I am of the old school as well & for the cost involved it's worth changing it.I do mine at 5 years buying a good quality A/F.:thumbsup:Confusedalut:
  • GJT
Thanks for the replies. Out of curiosity, I did a bit more searching on the 'net and nowhere could I find a reference to 'coolant for the life of the vehicle'. Five years seems to be the norm with modern cars, changing it using the coolant recommended in the manufacturer's handbook. Of course, in their wisdom, neither Citroen nor Peugeot recommend a coolant or tell us what was used originally on the basis that they don't seem to expect you to change it. I dare say a dealer could tell me but how daft. I'll be following Ron's example and buying a quality product and making sure the system gets flushed.
I'm pretty certain that Ed from 'Wheeler Dealers' used a 'lifetime' rated coolant on one of the cars they fixed up.
But that one was a special liquid that didn't contain any water at all, and was supposedly very expensive.
Edit:
By The Power of GOOGLE!
*Strikes a goofy pose*
http://www.evanscoolants.com
Ford use a long life coolant in their 1.6 PSA engine's so i think you must be able to use that
Side Light Bulb Holder
Yesterday 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
