Threads: 2
Hi, ive already posted this problem up but i never managed to get it solved, and to be honest wasnt to concerned as the van has been working fine with it, but now im looking to sell it and need to get it sorted. The problem is with my 51 plate hdi which runs fine until i brake to come to a stop and the engine management light comes on and the revs drop down until i release the brake pedal again and then the revs will go back up again and be fine. Has anyone had similar issues at all? any help would be great. thanks.
Threads: 17
Thanks Received: 40 in 32 posts
Thanks Given: 6
As it's diesel, you probably have a vacuum pump. Check any pipework involved for leaks.
Griff
Landmark
Ex 1.4 Berlingo Multispace
Threads: 2
nice one i will check it over would this not cause a loss of power?
Threads: 23
Thanks Given: 50
29
The vacuum pipe for the brake servo or the servo it self
Threads: 63
Thanks Given: 410
Vacuum pipe is also connected to the solenoid for the EGR system so perhaps worht having a look around that area too ???
Threads: 2
Does the eml go off when you release the brake?
You need to read the stored/pending codes to see which code has popped up
