  • 3 Vote(s) - 4 Average
Driveshaft boot clamp
Hi folks,
is it possible to get a replacement driveshaft boot clamp on its own or do I have to buy a complete kit? Whilst cleaning up my brake discs a couple of weeks ago I noticed that the clamp had split, managed to fit a very strong cable tie in its place as a temporary measure but it has started to loose grease all over the the inside of the hub assembly. Hopeing I can get it fixed without having to strip every thing down as the boots are both in very good condition.
Thanks,
Dave.
Yes you can a local garage will do it or you can get a DIY kit or if you know some one in your neighbourhood that fixes car's Citroen will charge around £47
Somehing like these?
http://www.ebay.com/itm/4-PAIRS-UNIVERSA...22&vxp=mtr
You also need a special tool for them.
http://www.ebay.com/itm/CV-BOOT-CLIPS-FI...27e659428e
This one is a bit on the expensive side but at least you can see how it looks.
Edit:
Buy more clamps than you need...
It's easy to overtighten the clamp the first time you try, and break it....
Thanks for the replies guys,
will have a word with the mechanics at work tomorrow and see if they have the necessary bits to fix it. Didn't fancy stripping everything down just to fit a clamp, was going to try a jubilee clip but might be a bit tight for room.
Thanks again folks,
Dave.
SmileSmileSmileSmile
07-04-2026 04:17 PM
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
