  • 5 Vote(s) - 4.2 Average
mk2 berlingo horn
Where is the horn on the mk2? whats involved replacing it?
Check it's not the horn contacts first, under the airbag and very common...
The horn is under the passenger side front corner behind the bumper Wink
after further reading I have found that horn works with key out, not with ignition on, so I guess if I remove cowls I can check wiring and earths and clean up the area a bit and hopefully it will sort it!
(16-07-2014, 06:50 PM)DEZZIE Wrote:  after further reading I have found that horn works with key out, not with ignition on, so I guess if I remove cowls I can check wiring and earths and clean up the area a bit and hopefully it will sort it!
The usual culprit with your problem is the earth under the airbag is inadequate, best solution there is to fix the cable with a self tapping screw instead of the push in fixing used by Citroen.
The black wire being pointed at with the screwdriver is the earth.
[Image: DSC05062.jpg]
Last Post: Triggermann
Today 01:47 PM
Today 12:50 PM
Yesterday 12:17 PM
Last Post: wbchevron
Yesterday 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
