Threads: 2
Thanks Given: 6
On my 1.6 diesel berlingo.
All of a sudden the steering has gone lumpy. The steering wheel doesn't return to centre on it's own after turning and when turning the steering wheel it is not a smooth turn. Also for the last three weeks there has been a slight fume smell in the car at times.
The steering fluid level is ok and there would appear to be no readily visible leaks.
Are the two things connected and what would be the possible causes?
Thanks Given: 188
23
Have a look at the universal joint at the bottom of the steering column they tend to dry out. You can see it if you look down the back of engine, just aim some spray grease at it. Not sure about the smell have you got a pollen filter and if so has it been changed recently.
Are we there yet?????
• colin444
Threads: 2
Thanks Given: 6
Ok, many thanks for the replies.
I have greased the lower uv joint and run the car round the local car park to turn the lock back and forth and it seems to be a lot smoother. Where am I looking to access the top uv joint, please?
I'm not familiar with this car yet, can you give me a bit more direction with the injectors, please?
Threads: 2
If the smell is exhaust fumes smell in your cab then probably your injectors are blowing.
If you pull the engine cover off you will see your injectors , stick your hand above each in turn and if any are blowing you will feel it.
You might even be able to see exhaust fumes escaping as well and also oily gunk around the injectors too
The following 1 user says Thank You to homeruk for this post:1 user says Thank You to homeruk for this post
• colin444
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
The top uj is about a foot or 10" above the one you've lubricated, if you put your head under the dash, if you imagine the shaft that comes out of the steering wheel and goes back to the uj, follow the shaft from the other up and it's there (I think I removed the panel to the left of the fusebox cover to get a better spray angle on it)
The following 1 user says Thank You to dumdum for this post:1 user says Thank You to dumdum for this post
• colin444
Threads: 2
Thanks Given: 6
Many thanks for the replies.
I have located a weep at the union with an injector which may well account for the fume smell.
I will see over the next few days.
Threads: 2
Thanks Given: 6
Finally sorted.
Although a bit of grease seemed to ease the uv joints, it had started to seize up again so these have now been replaced.
There is a bit of blow on one of the injectors and that will be done shortly.
Hope that's useful to anyone else with similar symptoms and thanks again for the replies and help.
