17-07-2014, 03:46 PM
Hello All,
I have a 2005 2.0hdi Multispace with 85000 miles on clock from new the problem is a bit unusual it starts 1st time when cold but if I turn off the engine after a journey and return 5 minutes later sometimes it shows no sign of starting but if I leave it for 15 minutes without turning it over it resets itself and off it goes no problem.
My garage had a look and replaced the diesel filter but it is still doing it, now they are now talking about the Injectors could be to blame, I am just not convinced from what they say that this is the cause and it could cost some serious money and still not cure the problem, I do appreciate when a fault is intermittent it is hard to track down.
The vehicle does not have any excessive smoking or any problems I am aware of and is serviced regularly.
If any of the above rings a bell with you I would really appreciate some input as to your feelings regarding the cause.
Thank you
Dessie
Thank you
Dessie
unny:
