  • 3 Vote(s) - 2.33 Average
Locking doors with boot open
Hi, Is it possible to lock the car doors while the boot is open please (09) 1.6 XTR Diesel? I often need to leave the boot open for the dog, but I don't like the idea of having to leave the other doors unlocked.
It is on the mk2 (well mine anyway)
I take it your not in a position to try it,?
I do own the car, so yes I can try, if you could tell me how to isolate the boot. Is there a special sequence with the key? or is there an isolation switch?
Just lock the latch and it will lock as usual, but you will need to in latch it when you want to shut it again
Easiest way is to use a screwdriver or key to push the rotating section of the barrel around until it clicks (it may need to click twice if it's like a door catch)
Hope this helps
On my mk2, I just open the boot and lock the car using the remote key as normal.
Job done
There was a thread about this in the past.
I thought you just locked the car with the fob, then used the key to unlock the boot and the rest of the car and immobiliser are as normal..
If not, do a search. There was a post and simple solution as someone wanted to leave the boot part way open for a dog.
Dumdum is correct as I do this on my 2010 mk3 XTR
I don't think I can do this on my mk3 as the boot doesn't have a keyhole.
(18-07-2014, 03:36 PM)Mike Wrote:  I don't think I can do this on my mk3 as the boot doesn't have a keyhole.
There is no keyhole
You manually turn the catch on the bottom of the tailgate - you can use your finger, but it safer to use something else
Make sure you pull on the opening handle above the number plate to release the catch before closing the tailgate though
Wheel nuts
Today 10:16 AM
A Testing Question....
Today 09:59 AM
Yesterday 04:31 PM
Yesterday 11:13 AM
Last Post: JPCoetzee
15-03-2026 10:34 AM
13-03-2026 03:21 PM
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 02:49 PM
