  • 3 Vote(s) - 3.33 Average
Fuel De-pressurising
Hi all,
How is the fuel line on a M49 2002 1.4 model depressurised if there is no shroder valve. Is there a fuel sensor that can be unplugged like in other makes of cars to depressurise or is it a case of removing the fuel line from the fuel rail and just letting the fuel flow(spray) out into rags.
pitpan
Just unplug the fuel pump and crank the engine, it will run out of fuel and depressurise the rail, or just wrap it in wrags with a cold engine/exhaust and unplug the fuel line, not a lot comes out in reality, it's hard to compress liquids, so in reality I reckon you lose a deodorant cap full at most...
Hi PitPan,
Our model is the same year as yours and does have a valve at the clutch end of the rail. However, to quote Haynes manual "Where no valve is fitted to the fuel rail, it will be necessary to release the pressure as a fuel pipe is disconnected" It goes on to say to catch the fuel in a container and plug the pipe to stop further loss/dirt getting in.
HTH,
Griff
DumDum was faster typing then me :-)
Landmark
Ex 1.4 Berlingo Multispace
ah ok thanks guys.
Today 12:17 PM
Last Post: wbchevron
Today 09:32 AM
Yesterday 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
