  • 15 Vote(s) - 2.13 Average
Rear Disc Brakes
Hi!
Following on from my Newbie thread, i've wanting more power from my Berlingo.
This'll most likely take form of a 306 GTi6 Engine or a 406 SRi.
Obviously more power means i'm going to want more braking... I've had a look under the car and the beam looks suspiciously similar to a 405 Mi16... Any ideas if these will swap over??
If not, any other ways of doing it?
brembo slotted disks aren`t dear
brembo pads too
should make a nice differance
and pad changeover to a grippy pad for the drums.
I want to convert the rear drums to discs! On a deeper search, Xsara VTS beams fit.
I am planning to covert my brakes, but do these brakes really work well? Does this disc brakes work well with any model?
Car's with a better weight distrubution tend to rely more on their rear brakes. But as i'll be upgrading the fronts, i don't want braking overly biased to the front end.
(12-07-2011, 11:10 AM)Norledge Wrote:  Car's with a better weight distrubution tend to rely more on their rear brakes. But as i'll be upgrading the fronts, i don't want braking overly biased to the front end.
id strongly disagree with that. perfect braking distribution is 70% front 30% rear.
upgrade the front and thats all you need. the rear drums on berlingos are huge. they really work
also. why are most cars disk front and drum rear?
why do you go through 3 or 4 sets of front pads to 1 rear?
why do motorbikes have big twin front disks and small single rears?
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
