Faulty ECU?
Advice / Suggestions please. Earlier today our 03 2 litre HDi Van started misbehaving. It won't accelerate and has no power. The engine seems to be running fine otherwise! I'm guessing ECU trouble? Any thoughts? I know new ECU's from Citroen are very expensive so if it is the ECU any recommendations for re-build supplier?
White 2013 1.6 XTR , Green 2000 1.8 Forte,wheelchair adapted & Blue 2003 HDi Van
Before you start spending money on an ecu.
Is the eml on?
Can you rev above 3000rpm?
[-] The following 1 user says Thank You to homeruk for this post:
  • Bill
The ECU is the last thing that will be wrong with it, spend a little money on a diagnostic session , it may well be a simple fix.
Biggest issue with the hdi is the airflow meter .
  • Bill
Unplug the airflow meter and see if that cures it, it's a 5 or six pin plug attached to the air filter housing...
[-] The following 1 user says Thank You to dumdum for this post:
  • Bill
Solved! Air Intake moulded hose detached from air filter body. It's only a push fit! Now held on by cable tie. Van working perfectly. Thank you all.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
