  • 1 Vote(s) - 1 Average
Help please
Hi guys I have a 16 hdi and I'm fitting a new turbo tomorrow, I'm ok on this bit but I've got to change the oil pipe to the turbo, how easy is it to do ??? Thanks
It's a 57 plate
Sent from my iPad using Tapatalk
The oil feed pipe is situated behind the particulate fitter and wraps around the filter housing behind the heat shield, there are two banjo bolts one on either end and the torque is 22nm for the banjo bolts, you have to remove the heatshield and particulate filter to gain access, there three bolts in the top of the outer heat shield, two either side further down, then you need to remove the outer shield
Then undo both cat clamps and the two thirteen mm copper bolts either side near the bottom, the dpf will now slide out, and the back heatshield will come out aswell
The pipe starts about halfway up the block and twists and turns around the right side of the turbo... Don't lose the copper washers if you've not got new ones, there will be two at each end... Wink
You should also remove the sump and make sure the oil pick up pipe isn't all gunked up and give the sump a clean out too aswell as change the oil and filter too
[-] The following 2 users say Thank You to dumdum for this post:
  • ron, ronnie a
Thanks Ron
Yesterday 03:29 PM
Last Post: Triggermann
Yesterday 01:47 PM
15-07-2026 12:17 PM
Last Post: wbchevron
15-07-2026 09:32 AM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
