  • 1 Vote(s) - 4 Average
Fitting EGR Valve
I had our motor vehicle department at work stick their analyser gizmo on my 58 plate 1.6 XTR and the codes of P0409 EGR Solenoid Valve Sticking and P0489 EGR Circuit Valve Too Open came up. The car is getting a right pain to drive at times, hesitation on accelerating and now a warning on the dash and also with the engine logo illuminated. I need to replace the valve but could do with a bit of guidance as to how hard it is. Do I need to access the vehicle from underneath or is it all do-able from above? What do I have to remove to get access? Do I need any gaskets as well as the valve?
Not up to speed on the mk3
However before you spend your hard earned the first thing you need to do is give the valve a clean , in most cases thus solves egr problems.
Last Post: BigVtwin996
09-08-2026 12:10 PM
Eolys replacement tank
Last Post: jw4821
09-08-2026 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
