  • 3 Vote(s) - 3.33 Average
[Engine] Engine Hesitates.
Hi Everyone. I am not mechanically minded and need some guidance please. I have a new Belingo Multispace Diesel that hesitates on an irregular basis when at junctions, roundabouts or pulling away from traffic lights. This week it hesitated whilst overtaking, not a pleasant experience I can assure you.
When pulling away from lights/junction the engine slowly builds to its maximum revs in first gear and holds it for about three seconds before changing gear. On other occasions nothing happens then all of a sudden it surges and races away.
When overtaking it increased speed slightly then would not go any higher for at least five seconds.
No faults are recorded. I would like to be prepared when I take it into the Citroen dealers for the possible excuses they through at one.
Many thanks.
Could be a problem with the turbo but that's just a guess.
You need to be plugged into lexia then get it taken for a drive that should tell you what the problem is
[-] The following 1 user says Thank You to homeruk for this post:
  • Smee
Supermarket diesel caused me lots of running problems .I would take it back to the dealer .
[-] The following 1 user says Thank You to henry sb for this post:
  • Smee
Put in better quality of Diesel, and every couple tankfuls put in SuperDiesel
If it's eHdi it could need ecu update also.
[-] The following 2 users say Thank You to taxi for this post:
  • ron, Smee
Taxi.That's good advice.I mostly fill with Shell Or branded alternative. Never had a problem with fuel system.I also put in some millars or forte on long runs.:thumbsup:
  • Smee
Had big problem with my eHdi in cold weather using supermarket stuff
I lose about 70 miles a tank if I use supermarket fuel.
Its shell or esso for me , although the shell garage near me is terrible , it only seems to hire people for who English is not their first language and can barely speak a word of it and at least once a week it runs out of regular diesel.
Today 02:32 PM
Berlingo 2026
Last Post: xtimex
Today 05:06 AM
Yesterday 12:15 AM
Yesterday 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
Weird Air in Fuel Problem
Last Post: tomhick024
27-06-2026 03:25 PM
