  • 3 Vote(s) - 2 Average
Air con
Hi I had my air con regassed last September and now it is blowing hot air (no air con). Not sure if it could need regassing already, so I have tried to do some troubleshooting.
The compressor is kicking in when the dashboard switch is activated and cabin ventilator blower/fan is set to 1,2,3 0r 4. Should the engine radiator cooling fan also be starting to run?
The engine radiator cooling fan does operate when the engine temperature reaches about 95 deg, but I don't know if it should be running when the air con is switched on.
Thanks in advance for any help
2005 Berlingo Multispace 2.0 HDI
My fan always runs when the air conditioning is on
Chances are you have a leak.
You will need to have a leak test done to see if this is the case.
If the clutch comes in when you press the switch, then there is some gas still in the system, however if it is not cold it must be minimal. If the car was gassed that long ago, there will be a small leak, this will be extremely hard to find at first.
Today 02:50 PM
Today 02:31 PM
Today 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
