03-08-2014, 10:41 AM
Hi I have recently purchased a Berlingo Multispace with 1.9D engine. The problem I have is that the following items do not work properly:-
1 The instrument display partially works initially ie the fuel gauge, Indicator arrows illuminate and other indications illuminate for a few minutes and the go off. The only item remaining on is the charge lamp although the battery is well charged and the alternator output is almost 14 volts. Water temperature gauge, speedo, odometer and tachometer do not work.
2 The headlight dipped beam does not operate although sidelights and number plate lights operate OK also the main beam flasher operates OK
3 Windscreen wipers and washer do not work.
4 Radio does not work.
5 Blower does not work
6 Horn works OK until ignition key inserted
Indicators work OK and glow plug operation is via a hot wired pushbutton.
The engine starts and runs fine.
I have checked all fuses and they are OK.
I have disconnected the battery and reconnected it. Then I find that the headlight dipped beam, front windscreen wipers and speedo & tacho work for approx 1 second.
I would be grateful for any suggestions as to the next course of action to take.[font=Times New Roman][size=medium]
