oil consumption
Hi
I have a 2001 1.9D van 170K miles. I've run it for some time with the oil cooler by-passed, perhaps stupidly. Does anyone know if this would cause excessive oil consumption ie 1-2 Litres per 100 miles. Is it possible with the oil being too hot it would thin and more easily pass worn valve stem seals?
cheers weepaljoe
That's huge consumption!
Your engine must be really clean.
It could also be leaking past the piston rings.
What oil are you using?
[-] The following 1 user says Thank You to homeruk for this post:
  • weepaljoe
Is it smoking?With that sort of consumption it should either smoke or leave oil slicks(not kind to motorcyclists).Confusedcratch:
  • weepaljoe
I'm using 10/40 oil and its only smoking slightly and on starting. The oil strangely enough is black, despite re-filling at least weekly and usually more. I can't see any leaks on the road when parking
weepaljoe
Yesterday 02:50 PM
Yesterday 02:31 PM
Yesterday 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
