berlingo clutch pedal play
Wink
hi.
does anyone have a diagram for a berlingo 2008 1.6 hdi the clutch pedal assembly as my clutch seems to have a lot of play from side to side and when you press the pedal downwards it goes sideways a little, looks like a washer or pivot bush has broken or something, would be handy having a diagram, also the pedal is sqeeky when pressing down and driving me mad!
once i get a diagram i can find the part needed all going well.
many thanks to all.
My pedal was like that when I bought the vehicle ( admittedly a 1.9 ) tightening up the two securing bolts sorted it. Maybe you'll be lucky.
hi.
thanks for the info.
2 securing bolts? one bolt and nut at top then a bolt with a clip and the qhole pedal moves sideways so not sure if its a shim etc broken or just needs washers?
thanks
Mine has a nut and bolt which passes through the whole pedal unit ( it bolts in as a complete unit ) and a second bolt only which gives the pedal height position / free play. Like I say mine is a 1.9 so may be different to yours but it won't hurt your wallet to check, maybe ten minutes of your time including putting the tools away.
Hi stu, check this thread where I added some info when I fixed the same problem - turned out to be wear on the plastic parts joining the pedal to the cable holder.
http://www.berlingoforum.co.uk/showthread.php?tid=8895
The Berlingo I used to own had this problem (I also posted in the thread in the link). I ended up just living with it until I parted with the van and it never got worse.
Our Berlingo has this problem, as well. Anyone got a definitive answer??
Not the owner, just the bloke who looks after it.
ALL the owner does is drive it and put fuel in. Rolleyes
mine too .........any answers yet?????????????????????
Took my clutch pedal off, top pivot thin green nylon bush is worn out, anyone got a part number for it
lrb
The green bush on my clutch pedal is worn and causing play also, I need to get to a dealer to study the parts diagram. so I am interested if anyone has the part number for this bit also.
Yesterday 09:14 PM
Yesterday 03:21 PM
Last Post: JPCoetzee
12-03-2026 03:52 PM
OIL Drip
12-03-2026 01:49 PM
10-03-2026 10:47 PM
10-03-2026 09:14 PM
10-03-2026 02:49 PM
New owner in Bristol UK
10-03-2026 01:19 PM
Last Post: Alberts elbow
09-03-2026 10:11 PM
09-03-2026 05:17 PM
