  • 1 Vote(s) - 1 Average
Radio cassette code help needed please for X reg car
Hello
My battery was disconnected from the car last week, and now I need to input a code into the radio to get it working.
I don't know where to start with this and there's only me to do it.
Can I get hold of a free code anywhere, is it true that the code is printed on the rear, is it easy to remove, and is my radio a Blaupunkt or Phillips? (see pic below if it comes out!)
The car is an x reg if it helps.
Tara
[img][Image: IMG_20140807_133344895_zpsd92adfe1.jpg][/img]
Hi Tara,
The instructions to enter the code should be in your handbook (If you've lost it try a search to download one). I take it you have lost the code? Try your main dealer quoting the vin number and see if they can help.
HTH,
Griff
Landmark
Ex 1.4 Berlingo Multispace
Its highly unlikely to be on the rear, cause if it was then when the thief nicks your stereo he has the code to go with it!
However worth checking though cause if your not the first owner , a previous one might have done it so they dontlose it.
You can buy a radio removing tool from eBay its essentially two u shaped pieces of wire which are inserted into the holes on the left and right front side of your stereo , once home just pull and the stereo will come out
Cut up a hanger from the dry cleaners and make a pair of removal tools, that's all I use. They push in the holes to disengage the clips and allow it to pull out. It just cost a friend of mine £10 to get a code for his Corsa radio from a local radio fitter.
tensioner pulley
Last Post: RJBingham
Yesterday 07:18 PM
» Replies: 19
Eberspacher or similar
Last Post: David Edwards
15-02-2019 01:10 PM
Overheat and antipollution?
Last Post: mikeB
15-02-2019 11:39 AM
» Replies: 26
Last Post: Grizz
14-02-2019 10:04 PM
» Replies: 651
clutch pedal
Last Post: gissa
14-02-2019 12:43 PM
Engine noise
Last Post: cancunia
13-02-2019 12:40 PM
» Replies: 16
Valves DW8
Last Post: Arbe
13-02-2019 11:11 AM
» Replies: 51
throttle cable - where to get a good one.
Last Post: Arbe
12-02-2019 05:35 PM
2003 2.0 HDI Poor fuel consumption
Last Post: ffrenchie
12-02-2019 04:23 PM
» Replies: 31
New Berlingo Anyone????
11-02-2019 11:13 AM
