  • 1 Vote(s) - 3 Average
Waxoyl
I have been given a large drum of Waxoyl plus the relevant applicators, not been one to waste anything I intend to use it on my Berlingo. Anybody know of any do's & don'ts?
Thank you in anticipationConfusedalut:Confusedalut:Confusedtudy:Confusedtudy:
Lay a tarpaulin on the floor under the vehicle as it can be a messy affair, don't do it on the lawn either.
Best done on a warm day with the waxoyl warmed up in a bucket of hot water. Wear a pair of glasses just in case.
  • silverfox
was always told not to spray the brake pipes or at least wipe them clean after, A light coat of clear silicone grease is applied on them after
Ron's the man to ask he put's it on every thing including his toast :whistle: :thumbsup:
Don't forget to treat any rust etc before applying.
And make sure the underside is clean to.
Apply after a few dry days & in warm weather.Coat brake pipes with no fear(rubber as well).2 thin coats are better than 1 thick coat as what drips off doesn't rustproof.On "wear areas" mix with underseal & apply 1 week after original wax coat.The rear silencer can be treated as it doesn't get hot enough to burn but leave 24 h before long run.Any where rust is a risk,treat it.All nuts & bolts,batt terminals etc.
If spraying,use the lowest pressure poss to reduce waste.Confusedalut::thumbsup: Contrary to the misconception of one member,I don't put it on toast,I use axle grease.
  • silverfox
The Waxoyl that drips off can be used again by the way.
Today 06:32 AM
Clocks dropping out
Last Post: Micklew
Yesterday 09:29 PM
air con
Last Post: magoo1
Yesterday 04:56 PM
triangle light
Last Post: Buki
Yesterday 08:44 AM
16-07-2026 03:29 PM
Last Post: Triggermann
16-07-2026 01:47 PM
15-07-2026 12:17 PM
14-07-2026 01:49 PM
13-07-2026 10:07 PM
11-07-2026 12:02 PM
