Threads: 30
Thanks Received: 13 in 8 posts
Thanks Given: 2
Hi all, been through the threads and can't find if anyone has successfully disabled this feature. I do a lot of camping and charge phone up etc also i work remotely and sometimes need to run stuff.
I am more than happy to take the chance of running down my battery. I have managed for the last 20 years not to get caught out.
I want a feed to head unit (aftermarket) amp all 12v sockets and internal lights so bypassing is not an option.
Please tell me this can be disabled.
Threads: 2
Not that I'm aware of.
However if you have the modutop the sockets in the lockers are always live.
If not there's always the option of running a bypass and wiring your own live feeds direct to the battery.
Threads: 30
Thanks Given: 2
Is it the ignition live for the head unit or switched live that cuts out?
Threads: 29
Thanks Given: 67
20
Run a live straight from the battery connector in a decent size cable and take an accessory socket from it. Put a led light unit with it's own switch in the roof from it as well, shouldn't take too much doing.
Threads: 11
Thanks Received: 123 in 109 posts
Thanks Given: 16
8
You can adjust the timer in some bsi's with lexia and make it way longer than it is from the factory
