Threads: 15
Thanks Received: 3 in 3 posts
Thanks Given: 11
I've noticed the few times I've driven the Berlingo from cold the glow plug warning icon doesn't light up. Is this normal in warm weather, or should I be investigating a potential problem?
It's a 2006MY 1.6HDi 75.
The only reason I ask is my 330d (yes, I now it's a totally different car.....) lights the glow plug icon every time the ignition is switched on.
TIA,
Stuart.
Not the owner, just the bloke who looks after it.
ALL the owner does is drive it and put fuel in.
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
the 1.6 HDI hardly uses its glow plugs to assist starting. It will only illuminate on very cold mornings, below zero, so what you describe is quite normal.
Threads: 15
Thanks Given: 11
Cheers for ^^^ that. :thumbsup:
Threads: 16
Thanks Received: 31 in 22 posts
Thanks Given: 3
As above, glow plugs only kick in when very cold. I asked same question when I noticed mine didn't come on.
Threads: 63
Thanks Received: 192 in 171 posts
Thanks Given: 552
Mine only came on under 0°
I DO MISS MY BERLINGO
