  • 6 Vote(s) - 2.5 Average
REMOVING THE INNER DOOR PANEL
Hi could anyone please walk me through to removing the driver door panel on my Sreg multi space as I have a rattle :brickwall: behind here somewhere.
Thanks Mick
Looks as if nobody knows or is interested in your problem.
I sold my old partner a while ago so I'm trying to remember how to.
The door opening handle has a plastic clip surround. A twist of a screwdriver unclips it.
The door pull handle has a covering plastic strip that once removed with a small screwdriver allows access to two screws. Lever from the bottom.:thumbsup:
The door pocket has screws along the bottom and sides ((6?). ???. not sure about that )Confusedcratch:
The window winder may have a spring clip behind which can be pulled out with a hooked bit of wire or similar, the door panel has to be pushed in from the handle to see it, OR it is a pull off job with no clip
The panel should then pop off with a lever at the clips round the edges.
As far as I can remember that's about it.
Your rattle might be the guide for the window glass rotted through/broken and moving about, unlike the rest of the door its not galvanised.
:wave:
Many thanks will let you know how I get on
Just found this, great video.
https://www.youtube.com/watch?v=Ly9weQwM1vg
That's the way to do it , my one didn't have the speakers or electric windows but its refreshed my memory , Thanks .
Confusedalut:
Today 08:36 AM
» Replies: 15
Yesterday 05:12 PM
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
