Threads: 2
Thanks Given: 2
Hi
Advice sought
my 2001 berlingo 1.9 will not start or turn over. The glowplug relay CEP/6 is ticking fast/fluttering, is this the cause? The van will start with a push.
Threads: 29
Thanks Given: 67
20
16-08-2014, 09:04 AM
(This post was last modified: 16-08-2014, 09:24 AM by ffrenchie.)
More likely a battery or starter motor problem if it will not turn over. Will it turn over from a jump battery ?
Threads: 52
Thanks Given: 87
5
Have you checked the battery? Battery voltage with no load and again with engine running.
Threads: 2
Sounds like your battery is flat.
