oil leak 1.6 hdi
1.6 hdi year 2007 looses oil from the top. I already changed the Rocker cover with seal and the 2 seals behind the Vacuum pump.
Now there seems to be oil coming out in-between the cam cover and the head itself on the front left corner. I checked all the bolts and non was loose.
Here is my question:
Is there a seal in-between those two parts, or a liquid seal?
What is the easiest way to fix that problem?
Has anyone a diagram from the engine which gives further clues?
The seal is merely a gasket compound, so maybe yours has become broken. This is a very large job, as this cover holds the camshafts, and all injectors will need to be removed, and the mounting posts.
  • ron
thanks, thought so, -- if it does not get worse, I probably leave it well alone. Maybe my neighbour who is peugeot mechanic will take it on,-- ?
OK, got my neighbour on the job. I will change timing belt, tensioners and water pump at the same time including chain and sprockets. Injector seals were only done 10 000 km ago, so they should be OK.
08-10-2026 07:24 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
