  • 10 Vote(s) - 2.9 Average
larger turbocharger
I'm sure I've read it somewhere before, but for the I.6 hdi 90 bhp engine.
Wanting to know if possible to fit the bigger vns turbocharger from a 2.0 hdi onto the 1.6 hdi 75 bhp?
Any help be really aappreciated.
If you are talking about the Mk3 1.6 DHi 75hp, then this engine uses the same turbo as the 90hp version, the difference is a different ECU map
The 110hp version uses a VNT turbo to get the extra power
It's the face lift version of the mk1, so technically mk2 I have.
Got induction, exhaust and remap done.
Just wanting to see about uprating to the vnt turbo from the 2.0 litre, and injectors.
Then having another remap to accommodate the difference with the turbo. :-)
Before you go down this route make sure that
you have a clutch kit handy! The standard clutch is not
designed for the extra load you'll be putting through it.
but does the 2.0 hdi turbo fit?
project "black and decked" my bagged mk3 berlingo
This is what I'm trying to get answers for.
If it can be done, and what will need to get it done.
Turbo, ecu, injectors, modded inlet ect?
You'll have to check this out but I've been told the turbo from a Cummins M11 engine is a straight swap...
  • ATL_driver
Side Light Bulb Holder
Yesterday 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
