Threads: 50
Thanks Given: 743
If you have another key, try it. Sounds like an immobiliser problem...maybe.
Threads: 20
Thanks Given: 2,126
18
Does it have a fuel cut off button? Red,on L/H turret?
Strawberry flavoured windows
Thanks Given: 188
23
Is the key immobilizer key symbol flashing on the dash when you try to start it. Just a thought but did you transfer the immobilizer chip from the old case to the new case.
Are we there yet?????
Threads: 2
You haven't transferred your immobiliser chip to your new case.
Its small , black and square and sits in the corner of the case.
You can check this by holding the old key case as you would if it had a key blade still next to the hole the key goes in whilst you use your new key to start your car.
The following 1 user says Thank You to homeruk for this post:1 user says Thank You to homeruk for this post
• Ol'Jeffers
