  • 3 Vote(s) - 2.67 Average
Reversing sensors
Hi, I have just purchased a 2010 berlingo. The reversing sensors worked once but one they seem to have stopped. Can anyone help me get them working? Thank you
Hi There
Lets start with the easy solution.
You have not inadvertently turned them off on the switch have you?
The switch / button is on the right just down from the light switch :thumbsup:
Thanks, the switch that has a wifi type symbol on the right of the steering wheel does seem to do anything unless I lock the van then the led flashes red. Is that the switch?
(25-08-2014, 12:33 AM)Redjoe100 Wrote:  Thanks, the switch that has a wifi type symbol on the right of the steering wheel does seem to do anything unless I lock the van then the led flashes red. Is that the switch?
This is the switch on mine
Thanks for the picture. The button is in the same place but just has the wifi type logo. In the manual it refers to an alam but I don't think I have one. When I lock the van the led light on the button flashes at the same time as the one above the gear stick. Any other ideas? Thanks again
I tried my switch this morning and it just changes to a white light when pressed so I don't think it is the same switch, maybe it is an alarm? cant think why and alarm would have a separate switch, unless it's to enable the interior scan. All I can suggest is if you got it through a dealer you take it back and ask them why it has stopped working.
Thanks Trevor, I'll take it back to the dealer. This morning it beeped when I put it in reverse but I had changed nothing (the only difference is that it was raining). Do you know where the unit is located so I can take a quick look myself? Thanks again!
Sorry I don't know, buried somewhere I bet. Your switch does indeed sound like an Alarm, reading the manual today it says :-
Switch off the ignition, in the next 10 seconds press the button until the red diode is on continuously, get out the vehicle.... The separate switch you have does alarm the interior.
Thanks, after some poking around I have found that the button isnt a button its just and led mounted in a non working button and its for the alarm which I do have! The revesing sensors are after market and seem to be working now. Thank for your help
Last Post: rom4ik
Yesterday 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
