Threads: 2
Hi there, after some advice.
Looking at changing the 14" steel wheels on the van for some wider ones either 14 or 15". Any ideas which ones I can use?
Steve
Threads: 52
Thanks Given: 87
5
Which year/model do you have??
Threads: 52
Thanks Given: 87
5
OK, armed with that info I'm sure someone will be along to answer your question.
Threads: 12
Thanks Received: 69 in 55 posts
Thanks Given: 7
if its on 14s im taking its a mk2 shape so anything off a xsara, saxo, or Peugeot 206, 306 should fit as the alloys do
Threads: 8
Thanks Received: 5 in 5 posts
Thanks Given: 17
Pretty sure newer 20101 Berlingo wheels (which are 15" here in australia ) should go onto it..I am about to take the 17"a from my 2006 Berlingo and try them on my 2010 partner.tomorrow will let you know
Sent from my 3geesus using Tapatalk( it's ifail)
