  • 3 Vote(s) - 3.67 Average
Changing front passenger seat
Hello, I have a 2006 Partner Escapade (boo, hiss etc Wink). It's a car, not a van. The front passenger does not fold down flat and I'd like to swap it for one that does. I'd get a garage to do it because I have no experience in this kind of thing. I may end up just PXing for a van instead! I can't decide.
I've searched various threads and not entirely sure on what does or doesn't fit.
Do vans and cars have different fittings? Will a MK1 fit into a MK2?
I've had a look on ebay over the past few months and all the pre-MK3 Berlingo/Partner/van/car seats look the same as what I have........ So it should be 'fairly' straightforward?
I would like the same feature on my 07 Escapade, Noel - make it much easier to kip in on the odd occassion.
I did read a bit on another forum that reckoned we need one that folds for rear access - so doesn't have the sliding doors,
maybe a van seat folds flat for rear access?
Mike
I think most of the folding ones I've seen on ebay come from vans. They're often described as having a plastic 'table' top when folded down. When folded flat they have two cup holders so the tradesman can have a brew! Not sure why they need two though?..... Because if the seat is down you're unlikely to have a passenger...
Anyway, they don't always state whether it's a folding seat but the cup holders and hard plastic 'table top' is the giveaway on the photos. Most sellers say they fit into both Berlingos and Partners but I think one thread on here mentioned grinding and welding things? So it didn't sound that straightforward.
I'd like it for the extra length (ladders etc) so you'd probably have to completely take out the single seater in the back. But I think a hinderance could be the 2 seater in the back that actually covers about 2/3rds of the width. So it's still not ideal?
I fitted pair of seats from a MK1 van to my MK2 van exactly the same bolts and fittings. The only thing I had to switch over was the seatbelt fastener as it had the seatbelt alarm switch in it.
One thing to be aware of is the folding seat does not slide forward and backwards, it is in a fixed position. (Well mine is anyway)
Another thing to be aware of is they don't fit straight in due to the way the van seats are fixed to the floor.
But more info in this post:
http://www.berlingoforum.co.uk/showthrea...enger+seat
2005 Enterprise 600 1.9D - It did 85 once but started to smell funny.
(10-09-2014, 03:35 PM)Silent_Bob Wrote:  I fitted pair of seats from a MK1 van to my MK2 van exactly the same bolts and fittings. The only thing I had to switch over was the seatbelt fastener as it had the seatbelt alarm switch in it.
Thanks Bob. Very helpful.
Just another point I thought I'd make if anyone else is thinking of doing this is that not all van front passenger seats fold. I guess it was an optional extra or only came with certain models. But certainly not all Berlingo and Partner vans have folding seats.
My berlingo mk 2 2003 model folds down. The back falls forward, to reveal the tray top, and then a 2nd lever tilts the whole seat (and back) forward I to passenger well.
Two levers, two actions.......-
A quick update on this thread, I've just fitted a tilting front seat from a 2007 van into my 2004 Multispace. I was looking on here to see if there were any tips for fitting the seat as at first I had a problem getting the bolt holes to line up.
As noted before, the tilting seat does not have runners and sits on a pressed steel frame. The frame is a very snug fit on the rear outside corner, so much so that I had to cut a flap in the carpet to allow the frame to drop into place. Behind the flap I cut was... a hole in the crossmember that allows the seat to fit in place. Other than that the holes in the seat frame line up with the captive nuts in the chassis. I also had to use my original seat belt pre tensioner as it has a longer cable than the one that came with the seat. I'm hoping that I can fit the under seat storage to the driver's seat.
If anyone wants a blue multispace passenger seat, let me know!
4x 15" Alloys with tyres
Last Post: Guanajuato
Today 12:46 PM
Peugeot Partner 03 Van owner
Last Post: Art b
Today 09:19 AM
Titsup
Last Post: Art b
Today 09:17 AM
Last Post: Grizz
Today 07:50 AM
» Replies: 701
Language changed by itself!
Today 07:01 AM
Washer motor queryt
Last Post: Lighty
Yesterday 08:28 PM
Can i get away with 205/70r15
Yesterday 01:09 PM
How I installed an oil catch can in the 1.6HDi
Last Post: saskak
Yesterday 12:24 PM
valve clearances
Last Post: rublehousen
Yesterday 08:52 AM
brake light switch
16-04-2019 08:45 PM
