  • 2 Vote(s) - 2 Average
Missing items - retrofit?
There are three things that i want to fit, as in retrofit i think its called.
Firstly, is the central console box. Ive read previous threads regarding this, and have saved some photos and part numbers to get from germany. I was wondering though whether citroen uk would be able to get them for me at a reasonable price, so ive sent them an email, but still awaiting reply. Suggestions much appreciated.
The second thing im missing is the rear torch. There is no cut out bit, so im wondering whether there is wiring behind the plastic whatnot, ie if i were to cut through the plastic would i find the wiring? Advise would be much appreciated.
Thirdly, im missing the internal rails. There are flaps where the roof rails would fit. But when i open the flaps, there doesnt seem to be anything for them to attach onto. Would somebody please be kind enough to take a photo of what is behind the open flap?
Thank you
I added the rear torch to mine. Very simple job and there was the wiring and connectors waiting behind the plastic that I cut out. On a RHD drive auto I'm not sure if the torch mounts on the right side or left. I've a LHD and it mounted on the right (passenger) side. I'm sure someone will be along with that info.
Here is a photo of inside the flap area. Sorry for depth of field - it was kind of cramped but it gives you the idea of what should be in there.
[Image: ehcdc5.jpg]
(28-08-2014, 05:53 AM)3rensho Wrote:  On a RHD drive auto I'm not sure if the torch mounts on the right side or left. I've a LHD and it mounted on the right (passenger) side. I'm sure someone will be along with that info.
Mine's a RHD and the torch is on the right hand side, looking forward.
(28-08-2014, 05:09 AM)Berl Wrote:  There are three things that i want to fit, as in retrofit i think its called.
Thank you
Hi there,everything you want should be available on Ebay i have seen them all many times for sale.Torches are usually about a tenner,internal bars anything from £40 upwards and the centre storage boxes do come up but you would have to be patient.but a huge saving would be had doing it this way.Hope this helps.
http://www.ebay.co.uk/itm/Citroen-C4-Ber...2c8a9749b6
Heres the torch for a start.
(28-08-2014, 07:45 AM)3rensho Wrote:  Here is a photo of inside the flap area. Sorry for depth of field - it was kind of cramped but it gives you the idea of what should be in there.
[Image: ehcdc5.jpg]
Thank you so much for the pix.
YIPPEE
Went to have another look behind my flaps, and looks exactly like yours, so now all i need is some 'curtain rails' and clothes hangers. Ooops i mean 'internal roof rails'.
xxx
Thanks for your replies Big Grin
I wondered about that wiring being there too. Do you need a different panel & any fittings to hold & charge the torch?
2015 Cactus Feel BlueHDi
2014 Dispatch Van LWB
Ex 2013 Berlingo XTR 1.6HDi 115 owner
Side Light Bulb Holder
Yesterday 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
