Threads: 23
Thanks Given: 50
29
C4 Picasso are the one's to go for the only thing is the rear dampers are to long so you will need to find some shorter one's or get them made up there is a member on here who as them on his black van look through the thread's on member's Berlingo's i think it's there :thumbsup:
Threads: 5
Thanks Received: 44 in 35 posts
Thanks Given: 4
Just run the stock rear dampers, mine is 'heavily' lowered and still uses the stock rear dampers without issue. The ones that come with the 306/Xsara coilies won't fit due to different mountings, but the fronts are fine to use.
Threads: 4
Thanks Given: 3
Thanks feuxlingo but how do I run rear dampers ?
Threads: 29
Thanks Given: 67
20
10-11-2014, 04:20 PM
(This post was last modified: 10-11-2014, 04:23 PM by ffrenchie.)
Are you looking to replace the torsion bars with some coil springs ? The rear dampers are only there to take the bounce out of the torsion bars which act as springs. If you want to mount coil overs to replace the present system you will need to strengthen the mounts to be load bearing which will be complicated.
Threads: 28
Thanks Received: 7 in 6 posts
The eBay link posted ^ are they suitable also for a 2006 1.9D? Cheers
2006 Citroen Berlingo 1.9 D - 69 BHP
1994 Renault Clio 1.8 16v - 212 BHP
1993 Renault Clio 1.8 RSi - 110 BHP
"There is no replacement for displacement"
