[Steering & Suspension] Judderng steering wheel
My Berlingo has recently developed a weird judder.
It comes and goes with no real pattern to it(Not going to drive around all that much until I know what is causing it...)
There's plenty of fluid in the reservoir. The suspension and stering feels tight when I jack it up and start pulling on parts.
There's a pressure sensor(I believe) on the high-pressure line from the servo pump which isn't connected to anything, so if the pressure is too low, I wouldn't get a warning.
(Artifact from my engine change earlier. There was no matching connector on the wiring loom it came with)
Assume that the pump and rack are original and have suffered nearly 130K miles on 'assorted quality' roads...
Are you sure the drive shafts are ok?
Griff
Landmark
Ex 1.4 Berlingo Multispace
Maybe a simple case of wheel balancing / alignment.
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
