Thanks Given: 3
Car battery flat after starting with leads it won't hold charge and engine management light is on
Threads: 67
Thanks Given: 238
50
New battery needed ? Get the old one tested first.
Won't hold charge - So you've had the alternator tested then ?
Serieal Berlingo owner
• Andy ramsay
Threads: 2
Have you had the codes read?
Threads: 67
Thanks Given: 238
50
[/quote]
I think it will be the alternator
[/quote]
Test it before spending.
• Andy ramsay
