need help with three main issues!
hey everyone I just just bought a 1998 1.9d for parts. Basically my everyday berlingo had the wings replaced in the past with cheap aftermarket wings which are full of rust. However the donor van is in pretty good shape so I've decided to fix it up and put it back on the road as a backup van. There are a few problems that need attention first, so any advice would be greatly appreciated. First problem is the rev needle shoots up when the ignition is turned on. Sometimes it falls back down then back up, other times it fills the clock and stays there. Secondly, the airbag warning light flashes continually, and thirdly, both door windows are jammed. The previous owner broke both winder handles trying to free them up, and even using vice grips on the splined shaft didn't work. I removed the glass and mechanism from the drivers door and checked all the cables which are free. So it looks like the main part is seized, so how do I remove the two spring loaded cables and can I buy new parts or do I need to source the whole mechanism? any help would be great.
Welcome to the forum Smile
1) Do a BSI reset
2) For airbag you need LEXIA to show you what is the problem.
3) I have no idea, i have electrical windows, sorry Smile
I don't think the 1998 model has a BSI...
(My 1999 doesn't. I think that came in 2000?)
Airbag is most probably the cable to the seatbelt tensioner, or more specifically, the plug on those wires, found under the seats.
Unplug and plug together a few times to rub off oxidation and you should be good to go.
For the winders...
You most probably have to buy the complete mechanism.
Try breakers or eBay.
Or you could soak them in WD40 for a few days and see if it's possible to unstick them.
[-] The following 1 user says Thank You to Gadgetman for this post:
  • brajomobil
(17-09-2014, 01:24 PM)Gadgetman Wrote:  I don't think the 1998 model has a BSI...
For the winders...
Powerflex Front Anti Roll Bar Bushes
Last Post: NANO_Vigo
Today 08:52 PM
Crankcase pressure reference values?
Last Post: saskak
Today 08:43 PM
Juddering when pulling away
Last Post: magoo
Today 08:30 PM
» Replies: 16
Last Post: Grizz
Today 07:47 PM
» Replies: 707
new member needing lots of help
Last Post: cancunia
Today 05:44 PM
2.0 hdi abs no communication from abs ecu
Last Post: cancunia
Today 04:48 PM
B9 Head Unit Upgrade
Last Post: dumdum
Today 03:56 PM
Longshot... dash pics required
Last Post: dumdum
Today 03:47 PM
Titsup
Last Post: Martinez
Today 12:55 PM
» Replies: 16
Replacement TPS Sensor
Last Post: Jamespworth
Today 12:34 PM
