16-09-2014, 04:35 PM
I attempted replaced the rear brake lines on my 2005 2.0 HDI van at the weekend with new copper pipes. Clamped the rubber brake pipes so i could remove the old coroded lines. Took them to my local Car accessories shop to get some new ones made up. When i got back the drivers side brake clamp had dropped off
and there was lots of brake fluid in the container that i had put under the rear hub to catch any spills. I think the master cylinder ran dry. I have topped up the system and tried to bleed the system but there seems to be a airlock somewhere that i cant get out. Also the STOP light is flashing on the dash. I have bled the front with no problems but the back seems to be a right pain. This is really doing my head in now. Cant get the brake pedal to go firm and when i turn the engine on the brake pedal is really easy to press.Is there a knack of removing an air lock or does the master cylinder need to be bled. Any help would be appreciated.
DEKA
and there was lots of brake fluid in the container that i had put under the rear hub to catch any spills. I think the master cylinder ran dry. I have topped up the system and tried to bleed the system but there seems to be a airlock somewhere that i cant get out. Also the STOP light is flashing on the dash. I have bled the front with no problems but the back seems to be a right pain. This is really doing my head in now. Cant get the brake pedal to go firm and when i turn the engine on the brake pedal is really easy to press.Is there a knack of removing an air lock or does the master cylinder need to be bled. Any help would be appreciated.Thanks
DEKA
alut:
It's too orangey for crow's It's just for me and my dog
