EGR valve - OBD errors
Hello
I check the obd errors on my car, and i got the next errors.
P0409 Electric EGR valve position copy signal : Valve sticking during the initialisation
P0401 Air system fault : Measured quantity of air higher than the setting
P1162 Position indicator signal of the EGR valve : Valve jammed during driving,
P0490 Electric EGR valve position copy signal : Positive loop gap, Position indicator signal of the EGR valve : Positive loop gap
Is there any other option instead of installing new EGR valve
Thanks for answering
Best regards
(26-09-2014, 05:47 AM)abrezo Wrote:  Is there any other option instead of installing new EGR valve
Yes you can remap ecu with EGR off Smile
Take it out clean it and hope for the best...
Hehe...
Yes i will do this also. But, is it possible, that this errors are related with some other problems, like fuel pressure sensor?
I have 1.6Hdi motor
Chances are a good clean will sort this and a check of its function when its off the car too will verify its operation.
Sounds like the valve is stuck partially open from those error codes.
Very straightforward to remove off the 1.6 too.
you can blank it off but it depend's which pump you have one will show eml light the other won't show the light or you can have a map to delete the egr no more problem's
Classic EGR faults, wouldn't expect any other issues.
Eolys replacement tank
Last Post: Harrythephot
14-08-2026 12:02 PM
14-08-2026 10:27 AM
Ahh bless them...
12-08-2026 04:54 PM
12-08-2026 04:45 PM
Last Post: stu76
12-08-2026 05:41 AM
Last Post: BigVtwin996
09-08-2026 12:10 PM
Warranty on parts
07-08-2026 04:17 PM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
