seat belt alarm speaker
Hi guys, wbere will I find the speaker that emits beeping noise when seat belt is not pushed in/connected.
Regards and thanks to all, if any, who reply,
Hugh.
In here http://i.imgur.com/f0eQWxz.jpg
Good luck reaching there though. There is a way without opening the unit...
If you silence that you will also silence all other sounds. If it's very important to you
I would nip to the scrappy and get an old seat belt buckle from another Berlingo and
just plug that into the receptacle. Cheap and effective.
(02-10-2014, 12:52 PM)Ol Wrote:  If you silence that you will also silence all other sounds. If it's very important to you
bit more involved than that im afraid, even with seatbelt plugged in  the thing still bleeps and only stops after a certain amount of time passes, and even then,if it rains and you use the wipers it starts beeping again..........annoying, yes, so it is very important to me lol.....driving me mad
thanks for info
Hi - unplug the connection under the drivers seat - then only the seat belt alarm will be disabled - and you can quickly enable it again.
(04-10-2014, 03:25 PM)Bryce Wrote:  Hi - unplug the connection under the drivers seat - then only the seat belt alarm will be disabled - and you can quickly enable it again.
aah, if only, been there, done that and got the t shirt. also changed seat belt receiver, so thats not the ansa either lol.
been told bsi unit, but at 600 + to change it, no way hose.......
now the alarm on the steering column circuit board, if that can be silenced........
Today 05:49 AM
Yesterday 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
