Threads: 34
Thanks Received: 6 in 3 posts
Thanks Given: 1
Hi,
Looking to change the brake pads for a 2008 1.6 HDI Berlingo (the newer B9 model).  Can any one confirm the correct  part (I think it is Eurocarparts 101545708).Â
Are there wear indicators on pads for the B9. Do I need any other tools (such as Torx bits) to change.Â
Threads: 23
Thanks Received: 501 in 458 posts
Thanks Given: 50
29
There two type's of brake pad's for the B9 one's with wear indicator's one's with out there are two way's to check look under the front of your berlingo to see if there is a wire fixed to the back of the pad's or go on line or ring them type in your reg or tell them it and they will tell the right one'sÂ
Threads: 41
Thanks Received: 405 in 362 posts
Thanks Given: 134
31
Remember that you don't always need to change your discs when you changing your disc pads, therefore you don't need to remove the calliper carrier.
You need a 15mm and a 13mm combination spanner and some way of levering the pistons back
