Threads: 30
Thanks Received: 13 in 8 posts
Thanks Given: 2
Hi all, can you help? I have noticed just these last couple of days when I park up i get a buzzing sound (like a coil of a faulty relay) which last's up to around a minute then goes off. I had a quick look and it seems as though it is coming from on top of the head somewhere although i could be wrong.
Threads: 17
Thanks Received: 28 in 19 posts
Thanks Given: 23
Not buzzing from me, but I do hear the engine fan slowing down kinda like a slowing ticking noise maybe could be what ye hearing.
Threads: 23
Thanks Given: 50
29
Could be the abs pump resetting it self or the servo vacuum leak
Threads: 15
Thanks Given: 46
5
If its humming like a motor it is the fan. If engine temp is high, ie driving slow or sitting in traffic, electric fan will run for up to minute after switching off.
Threads: 30
Thanks Given: 2
Def not the fan. I am a Engineer and know the sound very well. Will try and source it. Thanks for the help so far.
Threads: 35
Thanks Received: 119 in 88 posts
Thanks Given: 3
4
If you stick you head in the engine bay, does it appear to be coming from the rear left (drivers side) of the engine bay?
If it is, I've got the same, but I can't remember what it was
Thanks Received: 26 in 24 posts
Thanks Given: 52
it's meant to happen, it's just various things doing there job, which you wouldn't hear with the engine running
63 plate Berlingo working hard.....
Threads: 21
Thanks Received: 28 in 23 posts
Thanks Given: 26
Mine does the same, been told its a headlight motor faultyÂ
project "black and decked" my bagged mk3 berlingo
Threads: 30
Thanks Given: 2
Thanks, sometimes it buzzes sometimes it doesn't. Will check it out
