  • 3 Vote(s) - 3.33 Average
Ride heights
Hiya everybody,
Does anybody know what the difference is between the ride height of the multi space rear axle and the van rear axle?
Reason why I ask is I would like to carry more weight in the back of my multispace and as I need to change rear axles I am toying with the idea of fitting a van one instead.
Is there much of a weight difference you can carry?
Thanks for your help.
H
Somebody told me the torsion bars are thicker which should mean more weight is definitely possible. If I was getting another axle I would definitely make sure it's from a van instead of multispace. I don't know if there is also difference between van versions like 475, 500, 600 & 800.
doesnt matter what axle you put on it , unless you get it reclassified on the v5 you can be pulled and weighed if the cops think your over loaded.
Im fair sure getting the weights changed on the V5 wont be a paperwork exercise - there will be some inspection required no doubt if you have changed parts. PLUS you would be needing to tell insurance its modified.
Video
(06-10-2014, 12:40 AM)Kokain Wrote:  Somebody told me the torsion bars are thicker which should mean more weight is definitely possible.  If I was getting another axle I would definitely make sure it's from a van instead of multispace. I don't know if there is also difference between van versions like 475, 500, 600 & 800.
Thanks for this,
I take it from thid that there is no difference in ride height?
you may also have to change tires if you go down this route as the multispace has an 81 weight rated tire minimum and the vans want 88s.
(i have both and have to watch out when i switch to my spare winter tires that i use the right ones on each car)
Thanks for that Top drive,
Not an issue for me however , as my tyres are already 88's.
Bumper with led
Last Post: Lingo09
Yesterday 05:54 PM
Amdro boot jump for sale
Last Post: Jaybee
Yesterday 04:41 PM
Paint advice
Last Post: Andhall
Yesterday 02:35 PM
Should I buy this van?
Last Post: Duggie12
25-03-2025 09:27 PM
sliding door panel removal
Last Post: mojito
25-03-2025 07:13 PM
Twin Cam Chain Snapped need some Parts Advice
Last Post: kingy1912
25-03-2025 01:10 PM
Rumbling Noise 55-65mph
25-03-2025 01:06 PM
XL tyres
25-03-2025 01:03 PM
Last Post: deejay_xb
23-03-2025 10:06 AM
» Replies: 32
Unusual Braking Problem
23-03-2025 07:57 AM
