  • 14 Vote(s) - 3.29 Average
tyre pressure
ok iam going on hold next week so i thought i would check the correct tyre pressure in the book,,,,am i correct by saying a fully loaded car should have 34lbs in the fromt and 45 at the rear ,,, hell this seems a lot !!!! help:wave:
59` XTR 110
depends on the tires. id stick with recommended tire pressures for the tire than manufacturers specs
The recommended pressures, empty and fully loaded, are on a plate you can see after opening the drivers door (on my mk. 3). 2.4 and 3.2 bar respectively. 34.8 and 46.4 psi. I'd check with the tire manufacturer as well.
Tom
Rear seat belt breakage
Last Post: Mad one
Today 06:09 PM
Today 05:49 AM
Yesterday 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
